Need Help With case fans
i Have begun building my first pc and I would like to know how I install case fans.  I have the stock fans from the cooler master n200, do I just install the fan header onto the MB or what, it had this connecter on it that looked like a psu cable(I have the msi A75MA-E35). Thanks, this was written on my tablet.
On that board you have the following fan headers:
>Above motherboard - occupied - cpu fan
>Rear of motherboard slightly above the pciex16 slot - for a rear fan
>Front of motherboard slightly below the 24pin power input - for another fan
If you want more fans you can either run off the molex or grab some 3/4pin splitters.
Case can have the following - 1x 120mm top, 1x120mm rear, 1x120mm front, 1x120mm side.
As long as you can use a screwdriver you can install fans - this shows the orientation. Have the front of the case and intake, rear and top as exhaust and side as either (I'd go for intake to balance the static pressure)
You can plug them in into the motherboard system/case fan headers.  If you have molex to 3-pin fan adapters, you can connect them straight to your power supply.
If the fan goes directly to a 4 pin molex, just plug it into the power supply.
