Need help with building my first pc
hi guys, i went to youtube, different sites and everywhere to find out about parts and it is all just too confusing, so can some of you all give me a generalisation of what i should build and recommended budget for building a pc only for gaming.
also only with a single 1080p monitor at 60hz
Depends what you are looking for.
If you are on a low budget i would reccommend one of these.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7497356&CatId=332
with
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3295678&CatId=3669
can play bf3 on ultra 30-40fps with a little of overclocking,antialiasing and motion blur also have to be off. Have the card thats how i know. 60fps on high
Runs other games maxed out.
BTW the kit only comes with 4 gb of ramm. I would Recommend 8gb
Barebone kits are really good from a budget perspective but i am wondering why you are pairing a 550  with a barebones kit that uses an APU that basically already has a gpu on the machine that will not be compatable with crossfire when adding in a Nvidia card.
