Need help with build. No signal
Need help with my build, I put my system together and screen won't recieve signal. The graphics card is a gigabyte gtx 660. Starting think that is the problem. My system works I just can't get signal to the monitor.
Is the cable plugged into your motherboard or to the GPU? Is your computer on?
The GPU and yeah the computer is on cause the case led's and fans and the cpu fan is working.
