With that budget I personally think an AM3 build is the way to go - 8350,990fx board, 7950/70 (the prices are tumbling so grab one), plus the rest of your gear. Should be close to if not cheaper than the build you posted.
I know everyone is going to suggest the FX 8350 over the i5-3570K, and I am to. Not only is is a better bang for the buck, but it will be better at rendering. Maybe that will save you enough money to upgrade to a radeon 7950 (much faster than a 7870).
