Hey guys i am new around here i need a little help picking a new z97 motherboard,
i am looking for a z97 mobo with a 10 + 2 power phase and also support m.2 and 2way SLi
Thank you very much for the help
APG
APG
Big Asrock fan...
http://pcpartpicker.com/product/fLvRsY/asrock-motherboard-fatal1tyz97killer
You can easily go with that one... It have decent audio and network, good everything basically... But if you really need the 10 phases:
http://pcpartpicker.com/product/vkCwrH/asrock-motherboard-z97extreme6
I'm going to guess you already have the CPU? if so what CPU?
I can suggest you the Asus Maximus VII Hero. It's a true 8 + 2 digi VRM system so I guess can take a CPU at 5GHz and past if you're lucky enough. I don't know how well will do for LN2 but if you're going to do that go balls to the wall with the mobo.
Avoid asus at all costs.
Those are pretty nice boards.
