Need help with a £450 build
http://uk.pcpartpicker.com/p/2qkvX
I'm looking for a case that would store everything here. I was also wondering whether that was a suitable motherboard for the cpu.
The gpu may not be much, but I think it's good value, and it's more than enough for someone coming from a laptop with integrated graphics such as myself.
Do have a look and thanks for your time.
take a look into the fractal series, such as the fractal core 3000.
Don't buy a Core 3000, It's a full ATX tower and you have a micro ATX mobo.
I'd go with the Fractal Design Core 1000. I've worked with the Core 1000 and for a budget it is a great enclosure. It's cheap but the build quality is nothing to be sniffed at. However, There is next to no cable management - a problem that may be magnified due to the fact that you have a non modular PSU - and the slightly smaller issue of the PSU fan facing down onto the rest of the components, namely the CPU socket.
Even so, those problems are very slight and I would recommend it for your value system.
Also I would ask you to consider an R7 260X instead of the 7770. Only because it's newer.
Happy building!
http://uk.pcpartpicker.com/p/2r1rH
There's a 7850 for the same price as the 7770. No point spending extra for 2133 RAM, you won't see the difference.
If you want a small form factor build, I would go with the FM2 platform. A 760k, A75 (or greater) motherboard chipset, and a 7870.
the motherboard you selected could be used, but it isn't ideal. The M5A97 R2.0 is a really great choice.
Thank you!
Not sure if you missed it but the GPU you suggested is only 1GB memory.  That could potentially be a more limiting factor than the speed of the 7850 over the 7770.  I checked Skyrim on medium and got to 1GB just waking around.  Portal on low to med settings pulled 500+mb idle.
The 1GB 7850 is still a good card.  There are more shader units and such compared to the 7770, and will be much better.
I had a 1GB 7850, and it ran Bioshock Infinite on Ultra with decent framerates.  High is easily playable as well.  Most reviews at the time suggested that the 1GB was not far behind the 2GB version of the card in terms of performance.  Of course, your mileage may vary, but The 1GB 7850 is still a decent budget video card.
I went and checked some of my other games and 1GB is sufficient.  I had never done a check before.  When I was doing research I saw many builders suggesting 2GB minimum but I had no way to check as I did not have a game portfolio (first PC build for me).  I would support getting the 7850 over the 7770 knowing this now.
Vram is balanced with the performance of the card. Many people recommend 3GB of Vram for 1440p, and yet, 2GB cards offer the same performance at that resolution.
1GB is more than enough for 1080p. And there's no performance difference, across virtually all games, in comparison to the 2GB 7850. It's solid for £99. But there is a 2GB 7870 available for approximately £30 more.
