Need help with £700 build
Im new to Pc gaming and I'm wondering if this would be good and if they are all compatable.
I would prefer all products from amazon UK
I already have storage and a disk drive.
http://uk.pcpartpicker.com/user/andy0811/saved/2QHD
Would appresiate anything i should change or anything that would work better.
I have MX £50 more to spend!
Looks pretty good, I would recommend changing your plan slightly. Take away the16 gigs of ram and put in 8 gigs instead. Not much will change, and you can put the extra money into a better graphics card.
ahh awesome thanks :) is that a good graphics card already ?
If it's just a gaming PC you don't need 16 gb of ram, 8gb is more than enough for ALL games. If the system has only one graphics card a 860w platinum PSU is like the mother of overkill unless you plan to add a future graphics card or I don't know, charge your Tesla car from a usb port. 860w can be considered overkill by some people even in a 2 graphics card system. Running that fx 8350 on stock cooler is like having a vacuum cleaner near your desk that is permanently on. That being sad this system will be much, much more powerful and you will have a better overall gaming experience with it.
http://uk.pcpartpicker.com/p/23Umx
Ok thank you for that! thats the sort of help I needed :) you my friend are awesome :D
With the fan you listed will i need some heatsink paste ?
No, that aftermarket cooler comes with it's own thermal paste tube.
