Need help upgrading koroa(fedora) GNU/LINUX 23 to 24 thank you
i need help upgrading with koroa its fedora alternative to 23 to 24 when i do the commands it tells me i can not upgrade when i did what i was told. thanks
https://kororaproject.org/support/documentation/upgrading-korora
computer specs
80gig hd with korora 23 and win xp Professional 32bit
intel GMA 900 Graphics
12.1" XGA screen
2gigs ram
Intel® Pentium® M - Processor 1.80 ghz
6-cell battery
made in 2005
http://www.dell.com/content/topics/topic.aspx/global/products/latit/topics/en/latit_d410_sp_spec?c=us&l=en&cs=04
How about you paste the entire output where it says you cannot upgrade?
so i got this (try to add '--allowerasing' to command line to replace conflicting packages)
Does this work for you?
At what point in the process are you getting the error? (whcih command)
when i sudo dnf system-upgrade reboot i got a i can't upgrade message when i put--allowedrasing to sudo dnf system-upgrade download --releasever=24 it told me to enter my pass and its installing the upgrades
Ok sounds like its working.
If I was to guess your getting the error because korora has some non standard packages included that might be conflicting.
i say its very fast i am very new to this i came from windows
Any issues just post.
It should go fine as youve no dodgy hardware.
yeah i am so glad i have a intel wifi card it had a boardcom it i heard thats hard to play with
Error Summary
yeah ill reboot it and see what it does
Error: system is not ready for upgrade
yeah i got the error still but ill restart it anyway
hmm can you do the following
dnf repolist | fpaste
and paste the link
13:56 icethebite ~]$ dnf repolist | fpaste
Failed to synchronize cache for repo 'google-chrome', disabling.
Failed to synchronize cache for repo 'mirror.yandex.ru_fedora_russianfedora_russianfedora_free_fedora_releases_17_Everything_i386_os_russianfedora-free-release-17-1.R.noarch.rpm', disabling.
Uploading (1.4KiB)...
http://paste.fedoraproject.org/423086/18841314/ -> https://paste.fedoraproject.org/423086/18841314
Can you run ls -l /etc/yum.repos.d and paste the oputput
[14:00 icethebite ~]$ ls -l /etc/yum.repos.d
total 140
-rw-r--r--. 1 root root 181 Jan 6 2016 adobe.repo
-rw-r--r--. 1 root root 265 Sep 3 04:48 download.opensuse.org_repositories_home_zhonghuaren_Fedora_24_.repo
-rw-r--r--. 1 root root 1255 May 14 04:50 fedora.repo
-rw-r--r--. 1 root root 1270 May 14 04:50 fedora-updates.repo
-rw-r--r--. 1 root root 1328 May 14 04:50 fedora-updates-testing.repo
-rw-r--r--. 1 root root 226 Jan 6 2016 google-chrome.repo
-rw-r--r--. 1 root root 172 Jan 6 2016 google-earth.repo
-rw-r--r--. 1 root root 192 Jan 6 2016 google-talkplugin.repo
-rw-r--r--. 1 root root 166 Sep 3 04:54 home_icethebite_ftp.pbone.net.repo
-rw-r--r--. 1 root root 1556 May 14 04:50 korora.repo
-rw-r--r--. 1 root root 494 Aug 31 05:59 mirror.yandex.ru_fedora_russianfedora_russianfedora_free_fedora_releases_17_Everything_i386_os_russianfedora-free-release-17-1.R.noarch.rpm.repo
-rw-r--r--. 1 root root 136 Aug 20 10:34 opera.repo
-rw-r--r--. 1 root root 1241 Aug 24 01:10 rpmfusion-free-rawhide.repo
-rw-r--r--. 1 root root 1172 Aug 24 01:10 rpmfusion-free.repo
-rw-r--r--. 1 root root 1170 Aug 24 01:10 rpmfusion-free-updates.repo
-rw-r--r--. 1 root root 1230 Aug 24 01:10 rpmfusion-free-updates-testing.repo
-rw-r--r--. 1 root root 1295 Aug 24 01:15 rpmfusion-nonfree-rawhide.repo
-rw-r--r--. 1 root root 1217 Aug 24 01:15 rpmfusion-nonfree.repo
-rw-r--r--. 1 root root 1215 Aug 24 01:15 rpmfusion-nonfree-updates.repo
-rw-r--r--. 1 root root 1275 Aug 24 01:15 rpmfusion-nonfree-updates-testing.repo
-rw-r--r--. 1 root root 961 Jul 21 2015 russianfedora-free-rawhide.repo
-rw-r--r--. 1 root root 1187 Jul 21 2015 russianfedora-free.repo
-rw-r--r--. 1 root root 1009 Jul 21 2015 russianfedora-free-updates.repo
-rw-r--r--. 1 root root 1071 Jul 21 2015 russianfedora-free-updates-testing.repo
-rw-r--r--. 1 root root 1000 Jul 21 2015 russianfedora-nonfree-rawhide.repo
-rw-r--r--. 1 root root 1230 Jul 21 2015 russianfedora-nonfree.repo
-rw-r--r--. 1 root root 1048 Jul 21 2015 russianfedora-nonfree-updates.repo
-rw-r--r--. 1 root root 1110 Jul 21 2015 russianfedora-nonfree-updates-testing.repo
-rw-r--r--. 1 root root 177 Nov 15 2015 tech-3.repo
-rw-r--r--. 1 root root 205 Jan 6 2016 virtualbox.repo
huh.. thats.. interesting. Im positive most of these shouldn't be there. did you add any repos since you've been using Korora?
At the very least remove this first.
sudo rm -rf /etc/yum.repos.d/mirror.yandex.ru_fedora_russianfedora_russianfedora_free_fedora_releases_17_Everything_i386_os_russianfedora-free-release-17-1.R.noarch.rpm.repo
Lets remove the google stuff (you dont use earth do you?) we can add back chrome later
sudo rm -rf /etc/yum.repos.d/{google-chrome.repo,google-earth.repo,google-talkplugin.repo}
Do you know what any of these are?
tech-3.repo
chrome doesn't work on 32bit systems i perf firefox or tor i use the russain fedora for simple record but we can add thats stuff back later
i tired to install games and forgot to remove it since the adress didn't work
tech 3 is obs but doesn't work due to won't support opgl2
I think theres another repo for obs. For now i would suggest removing those repos and all the russianfedora repos using the command examples above
We can always ad them back in or look for a better source.
Usually these system upgrade errors always happen becuase a repo cant upgrade its self to the next release.
that command seems to not remove them for me because i keep ls -l /etc/yum.repos.d to look
USe the other command i listed
just change the end of the path for the various repos.
Or to remove all the russianfedora repos more esily
sudo rm -rf /etc/yum.repos.d/russian*
should i delete that one also even thought it is for 24?
Yeah ive never heard of it. Unless you know what its for
