Connecting multiple monitors for AMD Eyefinity technology couldn’t be simpler. There are four easy rules to remember:
The first two monitors can connect to the graphics card with any display output on your product: HDMI, VGA, DVI or DisplayPort.
The third (or greater) display must be connected to the graphics card via DisplayPort.
If your monitor does not have a DisplayPort connection, you will need an inexpensive active DisplayPort adapter for it. DVI to DP adapters can be had for less than $30 USD.2
Every family of GPUs supports a different maximum number of displays.
