Hello, I said to a friend I could try help him play a game he used to play back on 1998, it's called Warcraft: Orcs vs Humans. We both have 64-bit systems so compatibility mode isn't an option, I was thinking a virtual machine would work but if anyone knows an easier way to play this game it would be much appreciated!
Thanks in advance
It's really hard to run much older games on the newer OS's these days. A virtual machine is the ideal really, otherwise you'll have to jump through some hurdles to make it work if possible. You can try dos-box.
Here, check out this video.
https://www.youtube.com/watch?v=54bHcb2ows8
64bit systems shouldn't be an issue since Windows has both a 32 and 64 bit kernel. DOS Box would probably be the best option.
