Hi. I have managed to get almost all the way to my goal of using Looking Glass on a VM that I pass my EVGA RTX 3090ti to.
As long as I don’t add the:
<shmem name='looking-glass'>
<model type='ivshmem-plain'/>
<size unit='M'>32</size>
</shmem>
As long as this isn’t set, I can boot, install NVIDIA drivers, do everything. I add it, and it crashes on startup with a bunch of “VFIO_MAP_DMA failed: Invalid Argument” followed by a “qemu: hardware error: vfio: DMA mapping failed, unable to continue”.
Any help would be much appreciated!
Best regards,
Marco
Edit: here is the qemu log for the run, slightly abridged. I couldn’t upload a .txt file and didn’t find any formatting option similar to ‘spoiler’, apologies if this is gauche:
2022-12-10 08:42:55.405+0000: starting up libvirt version: 8.10.0, qemu version: 7.1.0, kernel: 6.0.11-arch1-1, hostname: marco-arch.lan
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/bin \
HOME=/var/lib/libvirt/qemu/domain-3-win11 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-3-win11/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-3-win11/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-3-win11/.config \
/usr/bin/qemu-system-x86_64 \
-name guest=win11,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-3-win11/master-key.aes"}' \
-blockdev '{"driver":"file","filename":"/usr/share/edk2/x64/OVMF_CODE.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash0-format","read-only":true,"driver":"raw","file":"libvirt-pflash0-storage"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/win11_VARS.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-pflash1-format","read-only":false,"driver":"raw","file":"libvirt-pflash1-storage"}' \
-machine pc-q35-7.1,usb=off,vmport=off,dump-guest-core=off,memory-backend=pc.ram,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-accel kvm \
-cpu host,migratable=on,hv-time=on,hv-relaxed=on,hv-vapic=on,hv-spinlocks=0x1fff \
-m 16384 \
-object '{"qom-type":"memory-backend-memfd","id":"pc.ram","share":true,"x-use-canonical-path-for-ramblock-id":false,"size":17179869184}' \
-overcommit mem-lock=off \
-smp 24,sockets=24,cores=1,threads=1 \
-uuid 8cd3fc3b-c2cf-4c6f-aa5d-dd2be7711cf3 \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=33,server=on,wait=off \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-hpet \
-no-shutdown \
-global ICH9-LPC.disable_s3=1 \
-global ICH9-LPC.disable_s4=1 \
-boot strict=on \
-device '{"driver":"pcie-root-port","port":16,"chassis":1,"id":"pci.1","bus":"pcie.0","multifunction":true,"addr":"0x2"}' \
-device '{"driver":"pcie-root-port","port":17,"chassis":2,"id":"pci.2","bus":"pcie.0","addr":"0x2.0x1"}' \
-device '{"driver":"pcie-root-port","port":18,"chassis":3,"id":"pci.3","bus":"pcie.0","addr":"0x2.0x2"}' \
-device '{"driver":"pcie-root-port","port":19,"chassis":4,"id":"pci.4","bus":"pcie.0","addr":"0x2.0x3"}' \
-device '{"driver":"pcie-root-port","port":20,"chassis":5,"id":"pci.5","bus":"pcie.0","addr":"0x2.0x4"}' \
-device '{"driver":"pcie-root-port","port":21,"chassis":6,"id":"pci.6","bus":"pcie.0","addr":"0x2.0x5"}' \
-device '{"driver":"pcie-root-port","port":22,"chassis":7,"id":"pci.7","bus":"pcie.0","addr":"0x2.0x6"}' \
-device '{"driver":"pcie-root-port","port":23,"chassis":8,"id":"pci.8","bus":"pcie.0","addr":"0x2.0x7"}' \
-device '{"driver":"pcie-root-port","port":24,"chassis":9,"id":"pci.9","bus":"pcie.0","multifunction":true,"addr":"0x3"}' \
-device '{"driver":"pcie-root-port","port":25,"chassis":10,"id":"pci.10","bus":"pcie.0","addr":"0x3.0x1"}' \
-device '{"driver":"pcie-root-port","port":26,"chassis":11,"id":"pci.11","bus":"pcie.0","addr":"0x3.0x2"}' \
-device '{"driver":"pcie-root-port","port":27,"chassis":12,"id":"pci.12","bus":"pcie.0","addr":"0x3.0x3"}' \
-device '{"driver":"pcie-root-port","port":28,"chassis":13,"id":"pci.13","bus":"pcie.0","addr":"0x3.0x4"}' \
-device '{"driver":"pcie-root-port","port":29,"chassis":14,"id":"pci.14","bus":"pcie.0","addr":"0x3.0x5"}' \
-device '{"driver":"pcie-root-port","port":30,"chassis":15,"id":"pci.15","bus":"pcie.0","addr":"0x3.0x6"}' \
-device '{"driver":"pcie-pci-bridge","id":"pci.16","bus":"pci.6","addr":"0x0"}' \
-device '{"driver":"qemu-xhci","p2":15,"p3":15,"id":"usb","bus":"pci.2","addr":"0x0"}' \
-device '{"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.3","addr":"0x0"}' \
-netdev tap,fd=34,id=hostnet0 \
-device '{"driver":"e1000e","netdev":"hostnet0","id":"net0","mac":"52:54:00:87:7a:b7","bus":"pci.1","addr":"0x0"}' \
-chardev pty,id=charserial0 \
-device '{"driver":"isa-serial","chardev":"charserial0","id":"serial0","index":0}' \
-chardev spicevmc,id=charchannel0,name=vdagent \
-device '{"driver":"virtserialport","bus":"virtio-serial0.0","nr":1,"chardev":"charchannel0","id":"channel0","name":"com.redhat.spice.0"}' \
-audiodev '{"id":"audio1","driver":"spice"}' \
-spice port=5900,addr=127.0.0.1,disable-ticketing=on,image-compression=off,seamless-migration=on \
-device '{"driver":"qxl-vga","id":"video0","max_outputs":1,"ram_size":67108864,"vram_size":67108864,"vram64_size_mb":0,"vgamem_mb":16,"bus":"pcie.0","addr":"0x1"}' \
-device '{"driver":"ich9-intel-hda","id":"sound0","bus":"pcie.0","addr":"0x1b"}' \
-device '{"driver":"hda-duplex","id":"sound0-codec0","bus":"sound0.0","cad":0,"audiodev":"audio1"}' \
-chardev spicevmc,id=charredir0,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir0","id":"redir0","bus":"usb.0","port":"2"}' \
-chardev spicevmc,id=charredir1,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir1","id":"redir1","bus":"usb.0","port":"3"}' \
-device '{"driver":"vfio-pci","host":"0000:01:00.0","id":"hostdev0","bus":"pci.4","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:01:00.1","id":"hostdev1","bus":"pci.5","addr":"0x0"}' \
-device '{"driver":"vfio-pci","host":"0000:03:00.0","id":"hostdev2","bootindex":1,"bus":"pci.7","addr":"0x0"}' \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-object '{"qom-type":"memory-backend-file","id":"shmmem-shmem0","mem-path":"/dev/shm/looking-glass","size":67108864,"share":true}' \
-device '{"driver":"ivshmem-plain","id":"shmem0","memdev":"shmmem-shmem0","bus":"pci.16","addr":"0x1"}' \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2022-12-10T08:43:02.535169Z qemu-system-x86_64: VFIO_MAP_DMA failed: Invalid argument
2022-12-10T08:43:02.535253Z qemu-system-x86_64: vfio_dma_map(0x55907c7c39d0, 0x380000000000, 0x800000000, 0x7f6257c00000) = -2 (No such file or directory)
2022-12-10T08:43:02.547739Z qemu-system-x86_64: VFIO_MAP_DMA failed: Invalid argument
2022-12-10T08:43:02.547785Z qemu-system-x86_64: vfio_dma_map(0x55907c7c39d0, 0x380800000000, 0x2000000, 0x7f6255c00000) = -22 (Invalid argument)
2022-12-10T08:43:02.758788Z qemu-system-x86_64: VFIO_MAP_DMA failed: Invalid argument
2022-12-10T08:43:02.758805Z qemu-system-x86_64: vfio_dma_map(0x55907c7c39d0, 0x380000000000, 0x800000000, 0x7f6257c00000) = -22 (Invalid argument)
2022-12-10T08:43:02.764125Z qemu-system-x86_64: VFIO_MAP_DMA failed: Invalid argument
2022-12-10T08:43:02.764135Z qemu-system-x86_64: vfio_dma_map(0x55907c7c39d0, 0x380800000000, 0x2000000, 0x7f6255c00000) = -22 (Invalid argument)
2022-12-10T08:43:02.769889Z qemu-system-x86_64: VFIO_MAP_DMA failed: Invalid argument
2022-12-10T08:43:02.769898Z qemu-system-x86_64: vfio_dma_map(0x55907c7c39d0, 0x384800000000, 0x4000000, 0x7f6adbffe000) = -22 (Invalid argument)
<<Hundreds of lines of registers>>
2022-12-10 08:43:04.479+0000: shutting down, reason=crashed
EDIT2: trying to use B6-rc1 and using the kernel module provided instead with DKMS yields the same problem. as soon as I try to run a VM with the /dev/kvmfr0 file configured, it crashes. log below:
2022-12-10 12:19:02.394+0000: starting up libvirt version: 8.10.0, qemu version: 7.1.0, kernel: 6.0.11-arch1-1, hostname: marco-arch.lan
LC_ALL=C \
HOME=/var/lib/libvirt/qemu/domain-10-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-10-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-10-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-10-win10/.config \
-name guest=win10,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-10-win10/master-key.aes"}' \
-blockdev '{"driver":"file","filename":"/usr/share/edk2/x64/OVMF_CODE.secboot.fd","node-name":"libvirt-pflash0-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/qemu/nvram/win10_VARS.fd","node-name":"libvirt-pflash1-storage","auto-read-only":true,"discard":"unmap"}' \
-machine pc-q35-7.1,usb=off,vmport=off,smm=on,dump-guest-core=off,memory-backend=pc.ram,pflash0=libvirt-pflash0-format,pflash1=libvirt-pflash1-format \
-accel kvm \
-global driver=cfi.pflash01,property=secure,value=on \
-m 16384 \
-object '{"qom-type":"memory-backend-ram","id":"pc.ram","size":17179869184}' \
-smp 12,sockets=12,cores=1,threads=1 \
-uuid 8435f7c9-0913-4b1e-89dc-e11c76b85ee6 \
-no-user-config \
-nodefaults \
-no-hpet \
-no-shutdown \
-boot strict=on \
-device '{"driver":"e1000e","netdev":"hostnet0","id":"net0","mac":"52:54:00:fe:82:19","bus":"pci.1","addr":"0x0"}' \
-device '{"driver":"usb-tablet","id":"input0","bus":"usb.0","port":"1"}' \
-device '{"driver":"vfio-pci","host":"0000:03:00.0","id":"hostdev0","bootindex":1,"bus":"pci.4","addr":"0x0"}' \
-device '{"driver":"ivshmem-plain","id":"shmem0","memdev":"looking-glass"}' \
-object '{"qom-type":"memory-backend-file","id":"looking-glass","mem-path":"/dev/kvmfr0","size":33554432,"share":true}' \
-msg timestamp=on
char device redirected to /dev/pts/2 (label charserial0)
2022-12-10T12:19:08.227546Z qemu-system-x86_64: VFIO_MAP_DMA failed: Invalid argument
2022-12-10T12:19:08.227571Z qemu-system-x86_64: vfio_dma_map(0x558fe17cba30, 0x384000000000, 0x2000000, 0x7fc359dff000) = -2 (No such file or directory)
<hundreds of registers>
