I am working on re-deploying my Proxmox and home network from scratch again, albeit differently this go around and looking for help / clarification as I go.
SEE:
1st [successful] attempt here
This time around, my cable modem feeds directly into my OpenWrt-flashed Netgear WAX206 router’s WAN port which then feeds my Proxmox host and everything else to follow in my network.
I still do not have any physical switches in the mix and intend to do everything virtually through software, etc.
MAIN GOALS
HARDWARE CONFIGURATION
++ utilize AR9280 mini PCIe wifi card installed in Proxmox host (via passthrough and/or virtualization, whichever is better overall)
++ deploy Netgear WAC720 AP to extend network to garage / side yard / back yard -
SECURITY
++ properly segmented & secured home network
+++ FreeRADIUS ?
+++ 802.1X ? -
ISOLATION
++ VLANS
+++ security cameras
+++ phones / tablets / TV’s / FireSticks / etc.
+++ lizard habitat automation hardware
+++ 3D printer -
ADBLOCKING
++ network-wide ad-blocking / DNS control / etc.
+++ AdGuard Home -
REMOTE ACCESS
++ TailScale (or similar) -and/or- VPN that allows me to access my home network from anywhere on all devices -
NETWORK / FAMILY MANAGEMENT
++ family network control (to limit the kids as needed) -
SELF-HOSTED SERVICES
++ Jellyfin (or similar)
++ Immich (or similar)
++ Home Assistant (or similar)
++ Mealie.io
++ Frigate
++ hopefully more … -
EXPLORE & PLAY WITH
++ IPv6
++ OpenWRT
+++ WiFi Fast Roaming ?
+++ WiFi mesh ?
++++ B.A.T.M.A.N. ?
So far I have a relatively flat network with just a couple of interfaces / SSIDs setup on OpenWrt running on the WAX206:
LAN ( 10.10.10.x ) - LAN1, LAN2, LAN3 (wired ports only atm)
IOT ( 10.10.20.x ) - 2 radios – 2.4GHz + 5.0GHz
GUEST ( 10.10.30.x ) - 2 radios – 2.4GHz + 5.0GHz
LAB ( 10.10.40.x ) - LAN4 (feeds Proxmox host’s “WAN”) && 2 radios – 2.4GHz + 5.0GHz
I haven’t had much time to think past here really, so suggestions for logical layouts / deployment schemes are welcome.
At the moment I have my Proxmox host stood up at:
vmbr0 [10.10.40.40/24, gateway 10.10.40.1]
with an Owrt VM running at:
vmbr0[10.10.40.50]
whose LAN is set to:
vmbr1[10.10.50.50/24]
I managed to pass wifi [wlp7s0] via direct PCIe passthrough to OpenWrt and installed the ath9k driver to get it operational using this tweak. I installed the intel-microcode package and wpad-mesh-openssl packages and configured my WiFi to match my main router’s SSID’s with same configs on both sides, including 802.11r fast roaming, 802.11RRM (802.11k + 802.11v).
