Hello,
So I'm planning on building a new PC for streaming, rendering, and gaming soon and the budget is around $2500 and I also need a 24" 1080p monitor with it and also an optical drive. So since I don't live in the states it would be better not to use PC part picker and use Newegg.ca instead.
Cheers
EDIT: The PC also needs to be extremely quiet.
All these builds are approximately $2000 CAD. The $500 remainder can be allocated on your choice of monitors or other components. And there's plenty of ways you can save money on each build.
1150 socket
http://ca.pcpartpicker.com/p/3JNEv
I haven't included a CPU cooler, I thought you might want to consider an all-in-one watercooler, or alternative. I don't know how much overclocking you wish to perform.
You could afford some pretty awesome monitors with the remainder of your budget. Ultra HD (1440p) or a higher refresh.
I placed two 1TB HDDs in the build. It's good to have a separate HDD to write to.
Alternate 2011 ATX build.
http://ca.pcpartpicker.com/p/3JNMn
Alternate AMD build. Very capable. Dual R9 290 configuration, which is gonna be good for productivity and gaming.
http://ca.pcpartpicker.com/p/3JNP0
why going socket 2011 with a 4820k?
Yeah, the 4820k isn't really worth it. Go 1150 instead.
+1 for the 1150 socket build.
So update on this I'm planning on getting the LGA 1150 build after doing a bit of research. Thanks for the help and feedback everyone really appreciate it!
I think that was a very good choice. What monitor are you going to choose?
I already have a 1080p 144hz 27" monitor right now I only needed a second one for streaming so probably a cheap 24" 1080p one for my chat and other applications. Also Thanks for the help!
