US? all around 300$ any reason you are looking at these specific monitors? better options in that price range
No I’m in Canada thats why the prices so damn high.
I’m open to any suggestions as well even if they aren’t any of the 4 I mentioned. Just looking to stay around $300 canadian pesos
ok so canadian pesos. i would go with the acer or benq. veiwsonic and aoc are cheaper brands and generally have lower quality parts. they are all pretty much the same. ideally you’d find a ips or at least va monitor, but you got to go with what you can get.
i would look around for better monitors for you but i honestly have no idea how to do that in the great white north.
Just checked through that amazon and picked this one, specs seem ok, but I have no idea about anything because have skipped all 1080p things for past years
and I cant contribute to this topic in any other way
no1 said it yet, but good luck having that 4 displays working with nv. Especially if one or all of them are meant to run @144Hz or with gsync or whatever.
I’ve heard some great quantity of horror stories there. Thus my advice is first buy 2, test them, and then get another one test, and another one if there are no issues.
they are looking for a monitor. not for four monitors =P
Scrap the two without freesync. Even if you are not using it, it will be a standard feature on almost any display going forward. So you want to have that in case you want to sell it again.
Personally I have two of the XG2401 (so the older model) and they are still working fine. Bought those a few years back so they are not perfect anymore. But that is gonna be true for any TN panel.
