Ok, So i'm having some troubel deciding which case i want. I like airflow and the color black in case.
So i either want a Cooler Master Haf XB or a nzxt Phantom 410. They are completely different, so i have no idea which one to pick. But any cas ei do pick has to be 90 dollars or less. I'm open to suggestions. tell what you think would be better for airflow,looks, and uprgadability.
Here's the 410. Probably has the best airflow out of these cases. But if there is a little noise in it. Like a noisey fan, It will echo through the case. I should know i have this one.
