TheJoe
January 17, 2013, 4:04am
1
im new to the website, i really dont know much about computers but will it be possible to build a pc that will run crysis, far cry?
hopefully i will get to do upgrades over time.
my budget is at 750 but also including windows 7 at the price .
will this build work?
http://pcpartpicker.com/p/xZTR
thanks.
Looks good, but there are better deals on the 2GB 7850 just on newegg alone.
Anyone of these would be better imo
Though, I believe a 7870 might be better if it's within budget. If it does go over budget, I'd consider the NZXT Tempest to save a few bucks
TheJoe
January 17, 2013, 5:25am
3
i will be getting the 7870 now rather than the one i had in the list before. should i stick with the 600w or go for a 500w? thanks for the help
DCWalt
January 17, 2013, 5:26am
4
this would be my list of parts at this price. i just posted basicly the same build on another thred and i stand by it :P
CPU: AMD FX-6200 3.8GHz Six Core ....................................$134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106010
Mother Board: MSI 760GM-P34 ............................................$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130657
RAM: G.Skill Ripjaws X Series 8GB (2 x 4GB) .......................$49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Graphics Card: EVGA GTX 650Ti 2GB Overclocked ............$179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130841
HDD: Western Digital WD Green 500GB .............................$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236155
PSU: Corsair Builder Series CX600 600Watt .......................$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Case: Xion Gaming Series XON-560_BK ............................$39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208052
total: ..................................................................................$614.93
this will run Crysis on low to medium settings. you won't be able to run it on max settings without spending around $1,000. I didn't include and optical drive (CD/DVD/Blu-Ray) becouse most people don't use then any more. if you need one you can get one for around $15 on newegg. hope this helps :)
Pretty sure that can run Crysis a lot higher than low or medium settings, Walt.
TheJoe
January 17, 2013, 5:45am
6
should i change the cpu from phenom II x 965 to fx? will it be a big difffrence, sorry i dont know much.
Fx 4300 would be your best bet for this setup/price range
DCWalt
January 17, 2013, 8:16am
9
the FX-6300 would be better. i already gave you a list of parts using the FX-6300 that meets your price range. why would you want to downgrade? those extra 2 cores will make a big difrence
TheJoe
January 17, 2013, 10:25pm
10
i was talking about your build my bad. thanks
If you're going to OC with the FX-4300 and 7870, I'd stick with the 600w. besides, it's very difficult to get quality PSU for $40.
