Need help on which mobo to buy
Im currently building a computer right now. I have a amd fx 6100 am3+ cpu and i was wondering what good motherboard should i buy?
Would anyone recommend this mobo to buy?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157262
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
my budget would probably be up to $120.
Thanks for any help
get a 990 board
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157281??
Get a 990 board, I totally agree with Maliktwohundred. It's the only high-end chipset for AMD CPU's.
thank you guys
thanks alot. really helped bro
