that search was on my entire SSD and that's the complete list of files and folders.
what's weird is that :
t@tsu:~$ sudo apt install ovmf
Reading package lists... Done
Building dependency tree
Reading state information... Done
ovmf is already the newest version (0~20161202.7bbe0b3e-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
as for steam i've done a complete reinstall of my system re-created the ZFS pools and remounted to home and rsync-ed and even though i still get that error message steam runs and operates correctly once i close it. ideally i'd like for this message to no longer show up at all but maybe we'll figure that out later
also I'm really curious is all of this even possible with the ZFS part mounted on another hard drive then the boot and without moving home? does this requirement come from most linux distros not giving you the option to install software in separate locations as seems to be the case?
yeah but then how do i tell virt-manager to create the raw image within that mountpoint it doesn't seem as though at any point in the process it allows us to choose it's placement.
also when in virt-manager i create the raw file even though nautilus (file browser) detects 2.9Tera of free space virt-manager only detects 200GB and if i create the 2.9T raw image system immediately opens up a warning of no more space on drive (obviously the system doesn't slow down or anything but it seems as though I'm set up wrong and when i write more than the free 200GB of my SSD I will run into issues)
It appears that your root partition is completely full. This is most likely because you created a filesystem in the default storage directory which is /var/lib/libvirt. This image needs to be deleted soon otherwise you'll run into serious issues. Linux REALLY doesn't like to be out of space on root.
I wouldn't. A zvol would perform faster.
For this, you want to make a zvol from zfs on the terminal, then point your new storage pool to /dev/zvol and in there, there should be some directories that match your pool paths. Find the proper path to your zvol and use that.
no these two things happened on two separate time frames. steam not running was after doing a rsync -arv /home-old /home
then I reinstalled and did the whole thing again and then steam displayed the message but ran when i closed it. then I created the big image file but that didn't cause any issue because i deleted it. I then tried (as I did last time) to copy over home unmount the zfs and put home back in it's place but this left almost every app dysfunctional so i reinstalled ubuntu.
Ok so here's what I've done :
ZFS part (composed of the 1T and 2T) mounted to the ext4 4T drive
will try to do a zvol there though I haven't understood it
in the meantime the SDD will hold native linux steam (not it's games) and no fiddling with the home partition.
@SgtAwesomesauce ugh hate to fail once again but I can't get past even the first line dnf isn't in the repos and I think it's the only proper way to install the listed dependencies which ...again aren't in the repos.
edit: it looks like dnf is fedora's apt-get. so i don't need it.. but that doesn't solve my missing package issues
t@tsu:~/edk2/CryptoPkg/Library/OpensslLib/openssl-1.0.2j$ patch -p1 -i ../EDKII_${OPENSSL_VER}.patch
patch: **** Can't open patch file ../EDKII_openssl-1.0.2j.patch : No such file or directory
I've gone and listed the files of both that folder and the parent (and the children) but there are no .patch files.
They seem quite convinced that that's all that would ever interest someone. We really do need other files? Could a simple copy-paste from an arch system of those files work? Given I probably only need them to be pointed to and not necessarily to have them interact with the local environment?
EDIT: on another note I ran this : https://wiki.ubuntu.com/UEFI/EDK2 guide and I have tons and tons and tons of files now am I looking for anything like these :
