Need help on choosing a GPU
I've narrowed my search down to 2
 http://www.newegg.com/Product/Product.aspx?Item=N82E16814202030
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
This is my case
 http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I really need to choose because they are both on sale.
Any help would be greatly appreciated
TimmyTimTim
Sorry about the writing. i dont know what happend.
both cards are great, just choose the one you like the most. ☺
I would say choose the second one because of the better cooling unit, but that's just me.
I would personally say the second because it doesn’t have the reference cooling and I could not find anything bad on it but that is only with about 10 min of searching
Mistress
dual fan instead of single fan, does not allways mean better cooling performance.
if you realy wanne know the diffrence, then you realy have to search on detailed benchmarks of those 2 models.. Sapphire are well known about theire gpu´s and great cooling solutions..
its just wich one you like, i think personaly that the diffrences are minimum.
i personaly like that single fan model, just for the looks, but ofc that dual fan card doesnt look bad either..
Thanks personaly I like the smooth look of the 1st one so I bought it :D
The first one  black red with single fan i realy like ittt
