Need help, New pc build super slow!
So I recently built a new pc
fx8320
samsung 120gb ssd
8gb crucial ballistixs ram 1600mhz
gtx 580 1.5 gb
windows 8.1
and it is rediculusly slow and I know it's not my internet connection because I play online games, download movie, and stream netflix just fine on my console (ps3). I recently installed the latest drivers for my motherboard, but that didnt seem to help. So I was wondering if you guys could let me know all the tricks To get my computer running as smooth as it should be. Some other info that might help I've got my pc hooked up to my hd tv via the graphics card with a dvi to hdmi converter. Also I have a 1TB wd blue hdd drive but due to limited sata cables I had to unplug it so I could use my optical drive to install windows. when I installed windows I just pick the quick settings I didnt do anything custom if that matters. Any help would be really appreciated.
What motherboard do you have? because its hard to believe that 1 ssd, 1 hdd and 1 optical drive cant be all plugged in at the same time.
What is your bios telling you? ram speed,cpu speed, etc....
How exactly is it slow?
Check the motherboard manufacturer for the CPU support list of your motherboard and then check what BIOS version you need for this 8320...
