I have an unconventional setup when it’s come to VFIO with two GPU’s, and due to the varus I’ve considered many different mounting options but only one GPU will fit, the GPU’s in question are:
- Gigabyte Radeon RX 5700 XT Aorus 8GB (2.5 slot, but really it’s a 3 slot due to that massive cooler)
- XFX AMD Radeon™ RX Vega 56 HBM2 8GB 3xDP HDMI Black Fan
I already have the Fractal Design Flex VRC-25 riser cable, and been going on and off about VFIO over the many many months…if not years.
So now I’m considering to buy a cheap but decent rotary tool and grind out a 3rd vertical expansion slot but looking at the PSU cage the grated holes make it much harder to mount the adapter PCB to it. So now I’m in a dilemma, since this is out of my field on this and I don’t want to make an irreversible mistake.
Right, my question, how can I mount the riser cable just a little bit away from the motherboard so I can mount the Vega56?
Ref: The PSU cage where the mounting points are
(I’ve checked, it’s the only way since the PCIE cables obstruct the placement of the vertical card, basically the vega has to be vertical since it has room for the enormous 5700 XT power cables and it also is PCIE 3.0 so putting it in the 2nd PCIEx16 is the way to go. MB: ASUS X570-F)
Also I tried mounting directly on the motherboard…the only problem is that the clearance is about 2-3mm and that’s not gonna fly, especially with the RX 5000 series thermals.
