Need Help Laptop
Can some one help me find a laptop that has a good battery 4 hours+ that is thin and can play games casualy and all for around $800 thanks in advance
http://www.newegg.com/Product/Product.aspx?Item=N82E16834216451
that one seems pretty good, actually amazingly good, although the gpu is a little weak it's plenty enough for casual gaming
http://www.newegg.com/Product/Product.aspx?Item=N82E16834126031
or this, if you prefer nvidia gpus
For $819 you could get this one:
http://shop.lenovo.com/us/en/laptops/ideapad/y-series/y510p/
http://shopping.hp.com/en_US/home-office/-/products/Laptops/Laptops?SearchParameter=%26%40QueryTerm%3D*%26brandlaptops_dte2%3DENVY%26CategoryUUIDLevelX%3DjeEQxXjbj14AAAE0syxcZzOW%26%40Sort.TieredPricing%3D0&PageSize=15
i was thinking of the first one maxed out on the cpu and gpu screen 1080 and hybrid drive
