Need help in PC build
Would this pc wok?
Processor: AMD FX6300 black edition
GFX card: AMD Saphire HD7750 2gb DDR3
Ram: 8GB G skill sniper series
Power Supply: Antec basiq 430 watt 80 plus bronze
MOBO: I don't know what to call it so...:http://www.amazon.com/gp/product/B00DJ3DWFK/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
OS: Windows 7 SP1(OEM) 64 bit
HDD: WD Blue 1tb 7200 rpm drive
Optical drive: LG electronics 24x sata drive
Case: Fractal Design Core 1000
I also got a Hyper 212 EVO CPU fan with thermal paste i bought. , AMD fans are horrible.
Plus some case fans, a 120mm and 92mm fan.
So would this work? I already have the case, power supply, ram, and GFX card. I just plan on playing past gen games, maybe BF4 at med- high settings at 1080p.
i am sorry to say but you made quite a mistake with that gpu there... for the money after the huge pricedrops, the hd 7750 performs quite poorly for the price, since it's price hasn't dropped at all... I can straightly say that your GPU will be a bottleneck in this system, and you are gona be looking settings in bf4 more like low-medium and the fps will be around 30...
a build like this would have performed much better with the same price... http://pcpartpicker.com/p/2DUHk
with this gpu, you could have even played BF4 with ultra settings and over 30 FPS...
+1 to that build
whats your budget?
About 700 bucks US.
Well i can live without that one game. I can just play it on my PS4.
+1 on hoocee12's build.  You're not gonna get anywhere with a 7750.
