my pc as of now it severely drops frame rates from 60 to zero at random moments in game for a couple of sec I cant pick what causes this and I really don't have the money or time to just buy what is the top of the charts and replace my whole system I like running high to ultra settings in every game even though I don't have much of a budget any help would be appreciated also if u have any ideas on how to upgrade my build I wouldn't mind ether I am new on the site and really like what they have done keep it up
CPU i5-2500k @ 3.30 GHz
motherboard p8z68-vpro/gen3 ASUS socket LGA 1155
GPU 2 sapphire Radeon HD 6850 1GB GDDR 5
hard drive 1.0TB WD black hard drive 64MB
memory G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
power supply corsair RM 750 Watt
Antec DF-85 Black Steel / Plastic ATX Full Tower Computer Case
1 1080p monitor
windows 7 64-bit
Since you didn't list a budget, here's some good things to upgrade:
Grab a CPU cooler, like the Hyper 212 Plus/Evo, and overclock that i5
I'm not sure what's causing the stuttering, but I'm going to guess that the crossfired cards are getting old and that the games you're playing don't support crossfire. The AMD R9 270 would be a good single card solution without killing the budget. It plays high-max on most games, and you can't really complain at the price point the card is at.
Grab another 2x2 kit that's exactly the same as the RAM you have now
thank you very much for your heip I was going to buy my parts when taxes came in. price point around 1k and the games I mostly play are skyrim with mods and high def enb( hitman absolution)( total war shogun)(and the crisis series. I am going to learn how to overclock my cpu but need to learn how to mabie on the site and would crossfire amd r9 270 be good for my build or would u go to one higher card like the r9 280 ? I don't know mabie I should get just one r9 270 I don't know thanks again for the help.
1K is a really nice budget to upgrade. At minimum, I would get:
A nice cpu cooler, such as the noctua NH-d14 and then overclock that chip. Overclocking is actually relatively simple. Just increase the multiplier little by little, then test for stability. There are plenty of tutorials if you google how to overclock a cpu.
Another identical 2x2 kit, or upgrade to. 16 GB
GPU: r9 280x would suit you better. Going one step up to a GTX 780 or an r9 290 would be a great idea as well. I always suggest getting the strongest single video card solution before you start considering multiple GPUs.
if you want, you could also get a nice 120 GB SSD, to speed up your OS and a couple of games :)
Here would be good upgrades http://pcpartpicker.com/p/2F84q total would be around 720$ :)
that would indeed be a great upgrade. Install the OS and main programs onto your SSD, and put everything else on your hard drive.
