Alright, so I'm using CG Miner with this rig i built just recently. Now I'm pretty new to Litecoin and am very un-experienced when it comes to any of this.
Whenever i start up CG Miner the GPU's Fail. I have no idea what to do in terms of trouble shooting.
These are images of CG miner messages
http://postimg.org/image/9j4yh7cbx/
http://postimg.org/image/6x69nb4wh/
Theres the messages i get from CG Miner and here is my Config file.
I've redacted my username and password for obvious reasons.
{ "pools" : [ { "url" : "stratum+tcp://us.litecoinpool.org:3333", "user" : "", "pass" : "" }, { "url" : "stratum+tcp://us2.litecoinpool.org:3333", "user" : "", "pass" : "" } ] , "intensity" : "20", "vectors" : "1", "worksize" : "256", "kernel" : "scrypt", "lookup-gap" : "2", "thread-concurrency" : "32765", "shaders" : "0", "gpu-engine" : "1000", "gpu-fan" : "40-100", "gpu-memclock" : "1350", "gpu-memdiff" : "0", "gpu-powertune" : "20", "gpu-vddc" : "0.000", "temp-cutoff" : "99", "temp-overheat" : "95", "temp-target" : "90", "api-mcast-port" : "4028", "api-port" : "4028", "expiry" : "120", "failover-only" : true, "gpu-dyninterval" : "7", "gpu-platform" : "0", "gpu-threads" : "1", "hotplug" : "5", "log" : "5", "no-pool-disable" : true, "per-device-stats" : true, "protocol-dump" : true, "queue" : "1", "scan-time" : "60", "scrypt" : true, "temp-hysteresis" : "3", "verbose" : true, "worktime" : true, "shares" : "0", "kernel-path" : "/usr/local/bin" }
Sys Specs: 8 gigs Ripjaw ramm
250 HDD
3 R9 290 Shappire
1300w PS
Asrock 970 motherboard ( I think)
AMD Sempron 2.6 ghz.
I really have no idea how to troubleshoot this...
