Need help for building Gaming PC (500-700EUR)
Hello ladies and gentlemen.
My name is Dāvis and I'm from Latvia.
Today I am turning to you for help, to knowledgeable people.
This is my first PC Build, until now I have not done nothing like this.
Are there any suggestions for what I should be followed ? Which part should I change ?
Do I need a better PSU  ?
Part list.
CPU: AMD FX-8350 Vishera
MOBOGigabyte GA-970A-DS3P
GPU: Gigabyte Radeon R9 270X 4GB
CPU COOLER: DEEPCOOL GAMMAXX S40 CPU Cooler 4 Heatpipes 120mm
PSU: Evga 600B PSU 80Plus Bronze 600W
RAM: Kingston 8GB DDR3 PC14900 CL10 DIMM HyperX Fury Black Series
HDD: Hitachi Travelstar 7K1000 1TB 7200RPM SATA3 32MB
SSD:  Kingston HyperX Fury SSD 120GB 2.5'' SATA3 MLC, 7mm
CASE: IN WIN MIDI TOWER GT1 WHITE
OS I will probably install Windows 7.
Thank you!
Ok, a couple of thoughts here.
First, the 8350 is not a good match for the 970 chipset, these boards are in general not meant to handle the power-hunger of the 125W Vishera-CPUs, especially overclocked which you'll defenitely want to do when getting the 8350. A 990FX-Board would be much more suitable for that.
I put together an Intel-based build around 700€ for you, that will give you better overall performance, especially in gaming.
Check it out:
http://geizhals.at/eu/?cat=WL-492928
