Need help for a gaming pc build for 1800
Hello,im looking to build a gaming pc for around 1800 to 2000.Im only using the pc for gaming and mild video editing.I bought a origin pc for around 900 but its not what i thought it would be.
The equipment i would like to use /if helps/
:For the case i like the corsair graphite 760t because the look of the case its self and the amount of space in it
CPU:I really like the Intel haswell series cpu
Menory;16GB
Storage;1TB
Operating system in windows 7 64 bit
I have a razer death stalker keyboard and  a asus monitor and a mouse so im set there
Im not shore what other parts to use so any help is  appreciated.
Well , we have a budget but what do you intend on doing with it? What would you like to do?
^This
Do you need an OS and peripherals (Mouse, Keyboard, Monitor)?
mostly gaming like arma 2 and 3 or battlefield 3
no i just need the pc i have all the os and peripherals
What bloody currency? Don't treat us like servants, give us some info man!
http://pcpartpicker.com/p/3I87D
Assuming you're in the US...
... gives you an ROG Z97 chipset and should leave you room for a Haswell refresh i7-4790k (for faster video processing) or i5-4690k (which should be more than enough) that will be released in the next month... should be sufficient overkill for what you're looking for and as futureproof as it gets since the board and CPU will have JUST gotten released...
cool thx for the help. thank you
