Need help fixing alt-tab issue
So for a while now I have been experiencing random alt tabbing from games that run in full screen... It occurs with a loading cursor also and the only programme I can relate to the problem is a windows process called "System Interrupts"
Despite looking all over the webs I have found no real solution...
As a side note the process normally takes 0.1% of my cpu however it spikes closer to 7% when It supposedly alt tabs me... Other programmes I run that may cause such an issue are razer comms yet closing that doesn't seem to help
or my drivers but tbh I have no Idea other than that... I do run dual screens however and never remember the issue before I got the 2 but this may be mere coincidence... Thanks anyway if you know what may be wrong and a possible fix...
I run an i7 4770k, R9 290 and win 8.1...
