The bare metal performance sucks and I can’t play most higher end games without lots of stuttering and FPS drops. Games a 390x should be able to handle no problem.
I’ve tried booting the hard disk and every other boot option but most booted to linux and the others failed to boot windows.
Booting the hard disk entry resulted in a black screen with a blinking white cursor. Sometimes (but not always) a “Windows Boot Manager… (hard disk not found)” entry shows up which fails to boot and puts be back at the boot device selection screen.
The VM boots on its own with a proper boot loader no problem from linux so what’s going on here? Is there any way to get this to dual boot on bare metal?
Based on your other thread I don’t think the disk is partitioned in the way it normally would be, looked to me like you ended up passing through a partition instead of the whole disk. Please provide fdisk -l output for the disk in question.
P.S. Would recommend passing through your entire SATA controller if that’s possible, that way everything works and operates like normal in a dual boot scenario because it will use the same driver for the controller instead of using like a VirtIO SCSI driver for VM and actual controller on bare metal. I used to pass through my entire disk but when trying to boot on bare metal sometimes it had to set up some things on boot or it wouldn’t boot at all but last I checked it boots on bare metal just fine since I pass the whole controller. Windows creates a hell of a lot of partitions… The 2.4GB partition I created though.
Disk /dev/sda: 477 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: ADATA SX900
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 68B86E5F-070E-453A-BC50-B8D3E343B8CF
Device Start End Sectors Size Type
/dev/sda1 2048 923647 921600 450M Windows recovery environment
/dev/sda2 923648 1128447 204800 100M EFI System
/dev/sda3 1128448 1161215 32768 16M Microsoft reserved
/dev/sda4 1161216 991636081 990474866 472.3G Microsoft basic data
/dev/sda5 991637504 993349631 1712128 836M Windows recovery environment
/dev/sda6 993351680 998457343 5105664 2.4G Microsoft basic data
/dev/sda7 998457344 1000214527 1757184 858M Windows recovery environment
I found an old XML, looks like this is how I set up the passthrough back when I used to pass the whole disk.
:~$ sudo fdisk -l
Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Disklabel type: dos <---------
Disk identifier: 0x2fb0da7b
Device Boot Start End Sectors Size Id Type
/dev/sda1 63 467668214 467668152 223G 83 Linux <---------
Disk /dev/sdb: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 3FCF3A12-6252-4558-99C0-EAD5C3AEE5FF
/dev/sdb1 2048 1050623 1048576 512M EFI System
/dev/sdb2 1050624 452083711 451033088 215.1G Linux filesystem
/dev/sdb3 452083712 468860927 16777216 8G Linux swap
That confirms it alright… Do I need to reinstall in that case?
Not sure if I can pass the whole controller through but the linux host system is on a m.2 so maybe it’s isolated. Any pointers on how to do that? I basically just touch the GUI one time to set it up so my memory is pretty fuzzy.
That’s odd regarding your windows partitions though… My installs only every create these 3:
It would be possible to migrate the data from underneath a partition to a real disk if you have space for it somewhere else temporarily but a reinstall may be faster depending how much you had set up. Not something I’ve done but the concept makes sense to me so it should work in practice, can’t condone it either way.
Since your other drive is /dev/sdb I doubt you can pass the controller, check if they’re connected to different controllers by looking at the symlinks under /sys/block. My M.2 is NVME so it’s on a different controller than my 2.5" SSD.
lrwxrwxrwx 1 root root 0 Feb 17 12:01 nvme0n1 -> ../devices/pci0000:00/0000:00:1b.0/0000:05:00.0/nvme/nvme0/nvme0n1
lrwxrwxrwx 1 root root 0 Feb 26 01:50 sda -> ../devices/pci0000:00/0000:00:17.0/ata37/host0/target0:0:0/0:0:0:0/block/sda
+-17.0 Intel Corporation 200 Series PCH SATA controller [AHCI mode]
+-1b.0-[05]----00.0 Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961
