I have a friend who’s on the brink of switching to Linux. But he’s skeptical about the flexibility of Linux as far as asthetics does. He thinks linux is stuck back in the days of only one desktop environment, and no way to customize it much.
I not only want to show him thats not true, but show him multiple desktop environments in the process.
I’m running a pretty standard Ubuntu 18.04. I like their interpretation of Gnome. But I was hoping you guys could suggest some desktop environments that I could install and switch to as a demonstration to him.
But if they need any complicated steps, I would ask if you please go over those steps, or at least link me to the steps to install them. It would be much appreciated.
I’m not sure if this is a low effort response, but could you maybe show him reddit.com/r/unixporn ? I’ve found I get a lot of inspiration for my *nix environments from their. I also greatly suggest finding out what his desires are for a DE, because you may show him hundreds and still not get through to him. Just some suggestions for you, but I hope this helps!
Edit: Also what’s nice about he subreddit is that the configuration files are typically available so if your friend loves one it’s typically pretty easy to setup!
I was just hoping to set up multiple desktops to show him in person. So he could fiddle around and see what he likes. I don’t mind messing up this Ubuntu installation. i don’t keep personal files on this machine. So thanks for some of the suggestions so far!
@Phantom I totally forgot about that linux scoop video! Thanks!
Ok, done with showing him the desktops. And he wanted an Ubuntu Gnome type experience. Which shocked me. He’s coming straight off Windows, but says he likes the way Ubuntu 18.04 is laid out. I figured he’d go with Cinnamon or something like that, but he didn’t.
Now I have a problem, where I’ve gotten all the extra desktop environments to uninstall, but there’s still a selection on login under that gear, that says Xfce session. I tried to log into it, and there’s no panel, there’s no programs, just the icons for my drives which I cannot open, and I can open the terminal for Xfce.
Why didn’t this option for an xfce session die when I got rid of Xubuntu? And why is it broken as all hell? I had to force a reboot from the terminal. WHY DOES IT HAVE A TERMINAL APP? It doesn’t have any other apps?
Some xfce4 packages must still be installed. I’ve always found it aggravating that apt will install all required dependencies and modules but wont remove them all with the same meta package name.
Try making sure theres nothing getting left with sudo apt-get clean && sudo apt-get autoremove
nate@Hawkeye-Pierce:~$ sudo apt-get clean && sudo apt-get autoremove
[sudo] password for nate:
Reading package lists… Done
Building dependency tree
Reading state information… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded
This right here. This is what I was looking for! Thank you!
This fixed it. No more xfce session. That’s awesome. Now I’m back to my stock Ubuntu.
Granted, I don’t mind. I don’t use this machine as daily, but just the fact there was something there that I wanted to get rid of after I got rid of it, irked me. Thanks.
