Hello everyone or whoever bothers to read this. I have put together a few different Micro-ATX builds and have narrowed it down to 2, one is Intel based and the other is AMD based. I'll post the specs for both down below, if you have any suggestions, like if you would change anything about the builds, feel free to let me know. One thing you need to keep in mind is I am in Canada so parts are more expensive. Thanks in advance :)
AMD Micro-ATX build
CPU: AMD 760k
Motherboard: Gigabyte GA-F2A88X-D3H
RAM: VisionTek Label 8GB (900408) (Cheapest 8GB DDR3 1600 RAM I could find...)
Storage: WD 1TB Caviar Blue
GPU: Sapphire Radeon R9 270X
Case: Antec GX700
PSU: Corsair CX500W (Could have went with the 430W but the 500W is 7 dollars more... So yea.)
Optical Drive: ASUS DRW-24F1ST 24X SATA DVD Writer Black
Operating System: Windows 7 Home Premium 64Bit
Total: $838.59
Intel Micro-ATX build
CPU: Intel Core i3-3240
Motherboard: Gigabyte GA-B75M-D3H
Case: Cooler Master N200
PSU: Corsair CX500W
Operating System: Windows 8.1 OEM (64Bit) (Most likely gonna stick with Windows 7 Home Premium 64Bit, 1 dollars difference between them)
Total: $832.23
I've been leaning more towards the AMD build since it's just a little cheaper and motherboard seems to be better.
This is a AMD ATX build I put together as well, the reason I wanted to go with Micro-ATX is because he doesn't have the biggest room and he would be getting the same performance with a smaller size computer, but here is the part list for ATX build.
TX build
CPU: AMD 760k
GPU: ASUS GTX 660 OC DirectCU 2GB (Comes with Splinter Cell Blacklist and Assassin's Creed 4 Black Flag)
Case: Antec GX700
PSU: Corsair CX500W
Total: $838.59
Total with Sapphire Radeon R9 270X: $851.25
