Need help deciding on a cpu :)
 Hi guys !
   I'm from romania and i would like to know which cpu would you recomend becouse i am on a strict buged and want to puild a gaming pc  ....
the AMD FX-8320 ( 764 Lei = 280 Dollars ) or INTEL I7-3770 (1340 Lei = 480 Dollars ) ... please keep in min that th part are more expensive over here and that's why i haveconverted te price :D
 Thanks , Rares
Depends on what you'd be doing!
If you're on a strict budget then isn't this pretty self explanatory? Go for the 8350.
well im going to use it for games most of the time and some video editing , but what i wanted to know if the i7 is so much better that the price between the two cpu is supported by the extra performence that the intel cpu sould have
if not i will probably get the 8320 and invest more in the gpu
No it isn't. Go for the 8320 and overclock it.
OK :D ... Thanks for the input  and sory if my english probabli gave you a headache :))
Hey im from Bulgaria :D neghbour!
So if your gona be gaming and video editing and stuff like that then the FX-8320 is like the 8350 but not overclocked so be shure to overclock it and with the money saved from the CPU,get a better GPU!
I wish you the best and good luck!
If your just gaming and don't plan to overclock at all check out the intel Core i5 3570 non k its the little brother to the i7 3770 non k. My little brother has the i7 3770 and he's enjoying it with excellent framerates.
i say the amd fx 8350
Buy the 8320 and just bump it up to 4ghz. The Piledrivers are fine for pretty much anything.
I use the FX-6300 and everything runs amazingly - particularly statistical analysis scripts that are optimised to make use of the number of cores available. So the 8320 could only be better really.
Get the i5 3570, i7 3770 or 8320.
In helping someone decide between several options, simply re-state those options. It will be sure to help them make a decision every time. -_-
