I have a budget of 90 dollars for a motherboard cpu combo.
I want my machine to be able to run something like TF2 without or with a cheap graphics card.
I picked out these motherboards and wanted to know which one of these is the best choice.
Also if you guys know of a better deal I really want to know.
Here they are:
http://www.newegg.com/Product/Product.aspx?Item=13-128-561&nm_mc=EMCPB-032013&cm_mmc=EMCPB-032013-_-PB032113-_-Item-_-13-128-561
http://www.newegg.com/Product/Product.aspx?Item=13-131-843&nm_mc=EMCPB-032013&cm_mmc=EMCPB-032013-_-PB-_-Item-_-13-131-843
http://www.newegg.com/Product/Product.aspx?Item=13-138-365&nm_mc=EMCPB-032013&cm_mmc=EMCPB-032013-_-PB-_-Item-_-13-138-365
I am using a small case so I need a micro atx motherboard or mini itx
Thank you
Zack
