Need help deciding: 9950x3d or Threadripper?
Gaming and video editing. The other option would be to have a setup similar to notebooks with Optimus, where I use the integrated GPU to render everything and have a single dedicated one handle the heavy lifting, or being passed through to a virtual machine when needed. The issue with that is it’s a setup not many have tried apart from the “look what I can do” factor. Say for example I want to have a video on a export on a virtual machine while playing a game on the host.
Also, on the topic of having a “hybrid” integrated/dedicated GPU setup, I don’t know if I’ll be able to use the dedicated GPU on the host right after shutting down the guest, without having to reboot the physical system. To me having 2 GPUs sounds like a more flexible solution.
If you’re wondering about the “full speed” thing, I think I already answered that question at the beginning of this post: there’s a performance loss by going x8/x8 instead of x16/x16. To be honest though I might have to suck it up and go with a mainstream platform because of costs alone…there’s a lot to think of.
I ended up getting Taichi X870E Lite through a sniper app (HotStock $10/month). It was impossible to buy it normally. They disappear before you can check out on Amazon, if you’re lucky enough to catch the drop.
But now its sitting on my living room table. Solid board. Just waiting for 9950x3d to be released and will upgrade existing system.
Threadripper is about Cores, Lanes & Memory Channels none of which really boost your gaming performance, X3D all day long…
