So I built my PC about 6-8 months ago, nothing has been changed or added since then.
For about 2-3 months I've been having a problem- randomly shutting down.
It can be doing something not very intensive eg.web browsing/youtube videos to something very intensive like BF4 gaming. It will even shut down while booting into windows.
I will admit my cable management is poor. So the first time it happened I simply unplugged 24pin and plugged it back in. And this works.
As you can imagine after a period of months this becomes frustrating.
Also as time has passed it is becoming more frequent- from maybe once every 24hrs of pc being on to once an hour (these are approximate not actual numbers).
To the point tonight where i couldnt actually log in (using windows) before it shut down again.
About 2 weeks ago, I thought it might be something to do with my OC and not enough volts or something. So i reduced my OC and volts. The problem is still here.
Earlier today when I was trying to fix the problem I went into UEFI BIOS and it was even crashing when I was in BIOS.
When it does crash the green lights on MOBO and GPU stay on, as if they are still getting power.
Do you think this is MOBO,PSU,CPU?
I'm stuck, any suggestions would be greatly appreciated.
Oh also I have not tried clear CMOS or anything yet.
Setup:
FX8350 @4.4 (was 4.6 but lowered due to problem)
ASUS 990FX REV 2.0
ASUS DCII HD7970 @1125Mhz (when gaming, otherwise stock everything)
Custom liquid cooling loop-just for CPU
Old HDD from old pre-built PC-years ago
Crucial M5 64GB-for boot drive
Many thanks,
Ben.
