Need help compiling gnome shell
I am trying to compile JUST gnome shell and not the entire DE.
I keep getting errors and getting stuck in general.
I do not know why it is getting pissy about everything being in a sub directory. It really should not make a huge difference.
My goal here is to build this into an RPM and then simply swap it with the gnome shell rpm I already have using yast on opensuse.
Any help would be greatly appreciated
192:/home/tjj226/Downloads/gnome-shell-gnome-3-18 # sh ./autogen.sh
+ Setting up submodules
fatal: Not a git repository (or any parent up to mount point /home)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
/usr/bin/gnome-autogen.sh
checking for automake >= 1.11.2...
testing automake... found 1.15
checking for autoreconf >= 2.53...
testing autoreconf... found 2.69
checking for intltool >= 0.25...
testing intltoolize... found 0.51.0
checking for pkg-config >= 0.14.0...
testing pkg-config... found 0.29
checking for gtk-doc >= 1.0...
testing gtkdocize... found 1.24
Checking for required M4 macros...
Warning: I am going to run configure' with no arguments.
If you wish to pass any to it, please specify them on the
./autogen.sh' command line.
Processing ./configure.ac
Running gtkdocize...
Running intltoolize...
Running autoreconf...
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force --warnings=no-portability -I m4 ${ACLOCAL_FLAGS}
autoreconf: configure.ac: tracing
autoreconf: configure.ac: creating directory config
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'config'.
libtoolize: copying file 'config/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
autoreconf: running: /usr/bin/autoconf --force --warnings=no-portability
autoreconf: running: /usr/bin/autoheader --force --warnings=no-portability
autoreconf: running: automake --add-missing --copy --force-missing --warnings=no-portability
configure.ac:19: installing 'config/compile'
configure.ac:24: installing 'config/config.guess'
configure.ac:24: installing 'config/config.sub'
configure.ac:13: installing 'config/install-sh'
configure.ac:13: installing 'config/missing'
configure.ac:247: error: required file 'src/gvc/Makefile.in' not found
browser-plugin/Makefile.am: installing 'config/depcomp'
src/Makefile.am:179: warning: source file '$(top_builddir)/js/js-resources.c' is in a subdirectory,
src/Makefile.am:179: but option 'subdir-objects' is disabled
automake: warning: possible forward-incompatibility.
automake: At least a source file is in a subdirectory, but the 'subdir-objects'
automake: automake option hasn't been enabled. For now, the corresponding output
automake: object file(s) will be placed in the top-level directory. However,
automake: this behaviour will change in future Automake versions: they will
automake: unconditionally cause object files to be placed in the same subdirectory
automake: of the corresponding sources.
automake: You are advised to start using 'subdir-objects' option throughout your
automake: project, to avoid future incompatibilities.
src/Makefile-st.am:112: warning: source file 'st/st-adjustment.c' is in a subdirectory,
src/Makefile-st.am:112: but option 'subdir-objects' is disabled
src/Makefile.am:63: 'src/Makefile-st.am' included from here
src/Makefile-st.am:112: warning: source file 'st/st-bin.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-border-image.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-box-layout.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-box-layout-child.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-button.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-clipboard.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-drawing-area.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-entry.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-focus-manager.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-generic-accessible.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-icon.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-icon-colors.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-im-text.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-label.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-private.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-scrollable.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-scroll-bar.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-scroll-view.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-shadow.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-texture-cache.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-theme.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-theme-context.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-theme-node.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-theme-node-drawing.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-theme-node-transition.c' is in a subdirectory,
src/Makefile-st.am:112: warning: source file 'st/st-widget.c' is in a subdirectory,
src/Makefile-st.am:142: warning: source file 'st/st-scroll-view-fade.c' is in a subdirectory,
src/Makefile-st.am:142: but option 'subdir-objects' is disabled
src/Makefile-tray.am:8: warning: source file 'tray/na-tray-child.c' is in a subdirectory,
src/Makefile-tray.am:8: but option 'subdir-objects' is disabled
src/Makefile.am:64: 'src/Makefile-tray.am' included from here
src/Makefile-tray.am:8: warning: source file 'tray/na-tray-manager.c' is in a subdirectory,
src/Makefile-calendar-server.am:5: warning: source file 'calendar-server/calendar-sources.c' is in a subdirectory,
src/Makefile-calendar-server.am:5: but option 'subdir-objects' is disabled
src/Makefile.am:65: 'src/Makefile-calendar-server.am' included from here
src/Makefile-calendar-server.am:5: warning: source file 'calendar-server/gnome-shell-calendar-server.c' is in a subdirectory,
src/Makefile.am:209: warning: source file '$(top_builddir)/js/js-resources.c' is in a subdirectory,
src/Makefile.am:209: but option 'subdir-objects' is disabled
src/Makefile-hotplug-sniffer.am:5: warning: source file 'hotplug-sniffer/shell-mime-sniffer.c' is in a subdirectory,
src/Makefile-hotplug-sniffer.am:5: but option 'subdir-objects' is disabled
src/Makefile.am:66: 'src/Makefile-hotplug-sniffer.am' included from here
src/Makefile-hotplug-sniffer.am:5: warning: source file 'hotplug-sniffer/hotplug-sniffer.c' is in a subdirectory,
src/Makefile.am:222: warning: source file '$(top_builddir)/js/js-resources.c' is in a subdirectory,
src/Makefile.am:222: but option 'subdir-objects' is disabled
src/Makefile-st.am:169: warning: source file 'st/test-theme.c' is in a subdirectory,
src/Makefile-st.am:169: but option 'subdir-objects' is disabled
autoreconf: automake failed with exit status: 1
Is this unmodified?
Yeah
The only other thing that should be mentioned is that I am trying to swap gnome shell from 3.18.3 with 3.18.4
I am not trying to upgrade. All I want to do is be able to modify gnome shell.
Right now all the settings and code base I need is compiled into a binary file, so I am trying to circumvent that.
I'm interested in your progress...
Bump
Also it seems like cmake is also not working as it should be.
cmake -DCMAKE_INSTALL_PREFIX=/usr/local -DBUILD_EXTENSION=OFF ../
CMake Error: The source directory "/home/tjj226" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
Wellllllllllllllllllllllllllllllllllllllllll
192:/home/tjj226/chrome-gnome-shell # ls
chrome-gnome-shell.doap chrome-web-store **
CMakeLists.txt
** connector debian extension .git .gitignore LICENSE README.md README.ru.md
Soooooooooooooooooooo wtf
