Need Help Choosing Video Card
Well I currently own a MSI Lightning II 5870 @ 1005Mhz/1225
Plays every game I have fine, (Playing @ 1080p)
[b]Except[/b] FF14, BF:BC2, and of course Crysis.
Those games eyecandy isn't maxed.
I Will be playing Battlefield 3 primarily when that launches.
I love eyecandy so I was wondering if I should upgrade to a gtx 580/570 or 6970/6950 flashed.
Also do I even need an upgrade? Should I just wait for the AMD 7xxx and GTX6xx. I haz the money now. This upgrade will be the last one. FOR AN UBER LONG TIME.
Thanks
i would probably wait for the time being. But y not get another 5870 in put it in crossfireX
Have you considered putting two mid-end cards in crossfire/SLI?
The 560 Tis perform outstanding in SLI. Better than a 580 for less money.
If I was you, 560 SLI is the way to go.
Also, you still got that 1090t? You might want to get an i5 or something a bit better. My 1055t @ 4GHz used to bottleneck 6850 crossfire.
wait did u just say your 5870 dosnt max Crysis or BFBC2. strange....dual 560Tis would b great but I assume if u have a 1090T your board probablly wont SLi without the hack? 6950 or 580 look like good options if you need a powerful card.
actually no, there are 2GB 570s now, get that wont dissapoint
well, its not constantly above 60 with all eyecandy.
Exit Fraps>set to max settings> cant tell difference
yeah i can play BC2 and crysis with no noticeable lag on my 5850
Turn down the AA if you want more fps since it makes such a small difference at 1080p but you pay for it big time performance wise
lol I found out in CCC I had it set to SSAA...not the MSAA hehe oops
pff, i7>1090t>i5
BloodDrunk said:
pff, i7>1090t>i5
How is an i5 worse than a 1090T?
Games hardly use hyperthreading, and the extra cache in i7s hardly make a difference. i7s and i5s are equal in games, so how is an i7 better than an i5 (presuming you're meaning in games)
When I upgraded from my 1055t @ 4GHz to my 2600k, there was a massive improvement in some games.
A sandy bridge i5 will beat any Phenom in games
I was talking in general, not gaming. Preference wise 2600k>1090t>2500k
I think I'll just wait then. ty for suggestions
