Need help choosing psu!
hi I recently bought a r9 280x for my pc I had a 500w psu it turned fine ran games but when I tried unigine heaven benchmark to make sure it was stable it crashed and it said the anti surge was activated so I didn't put under stress any more to not cause damage.so I'm looking for a new psu I have a very strict budget(due to spending £150 on gpu) and was looking at this psu
Artic Blue 750W Quad 12v Rails (32 amp max per Rail) 80+ Plus Bronze Power Supply with 12cm Cooling Fan - Featuring - Molex - SATA - Floppy - 20/24 Pin & 4 Pin connections
I know it's a cheapy but really can't spend more than that atm just wondering your opinion on wether it's enough to power my system and also what is ment by quad rail 12v is 32Ax4 or just 32A shared?
Many thanks
System:
And fx4100
12gb ram
Sapphire r9 280x dual x
1tb HD and 120gb ssd
Don't get it. Quad rails means that it splits up the current on the 12V onto 4 different rails, so it might not be able to drive your GPU at all. If that PSU goes, it'll probably take some of your hardware with it. Wait a while to get a decent PSU from a brand you can trust Like Corsair, XFX or EVGA.
What do you guys think of this psu
Thermaltake 530W Hamburg
http://www.aone.co.uk/ProdInfo.ASP?ProductID=4641
I would stick to Seasonic or XFX or Corsair and keep at least 20% overhead from system usage to PSU output on a single rail
Thermaltake makes good stuff for the most part, but, as a practical matter it is very likely that your system failed because it hit the wattage limit of your PSU. I would try and get a higher rated unit 600-750 watts is where you should aim for. I have a 7970 (the older version of a R9 280 if i'm not mistaken) in a similar system that runs off a Corsair CX600M PSU and that just barely is able to power that system.
