Need help choosing parts
  I am looking to build a computer but I haven't really kept up with MoBo specs and RAM lately so I need help choosing some good parts that will go with what I want my rig to be built off of.
The case I want to use is the Corsair Obsidian 900D found here --> http://www.corsair.com/us/pc-cases/obsidian-series-pc-case/obsidian-series-900d-super-tower-case.html
The GPU I want to use is the AMD R9 290x but I don't know which manufacture would the best to buy from so input would be greatly helpful on that. Also I plan on doing a dual GPU rig later on the future just little extra information.
The CPU I want to use is either the  AMD FX-8320 Vishera 3.5GHz eight core or the AMD FX-8350 Vishera 4.0GHz eight core, but that can be changed to anything that will run better with the GPU that I want to use so go ahead and change the CPU as much as you like that will give better speeds with the GPU.
The hard drive I would like to go with two SSDs and two HDDs as with those I have not been keeping up with what has a long life span or which is of better quality so anything input will help greatly.
  As with the PSU I don't what I want use yet because I don't know how much power this rig will need yet since I don't have everything I need on my list yet so anything that will give me a amount of power with the ability to upgrade and more to this rig later on will be good also would like it to be gold certified.
With the amount of RAM I want I would like to start at 16GBs then upgrade to 32GB to give it a more over kill/ make it slightly future proof since I don't want to build another for a long time.
As with the RAM, heatsink, and MoBo please go ahead and recommend anything that will give the best optimization with the GPU I would like to run on this rig an just a reminder I will be using a dual GPU set up in the future.
  If I have left anything out please let me know and just add it to the list of parts. This does not have a set price as I will be buying these parts over a period of time so you can pretty much do anything with in the guidelines I specified but don't get to crazy don't this to be a 10k desktop just something that is very powerful and that will last me quit some time with great airflow to keep this over killed computer nice and cool.
  Side note if I can run a water cooling system to just the CPU and not use a heatsink that would be okay as I do know the GPU I want has a set tempature of 95 degrees celsius the rig will get really hot so if I can while getting great airflow to the rest of it then go ahead and add that to the list as well.
Thank you to anyone who helps me with this I know its long an I'm sorry bout that just wanted to addas much detail as I could to make it easier on you guys to help me with this.
  Kind regards,
Zakox
GPU will have a blower style cooler if you're buying it today/around now, so most of the hot air should be pushed out of the case.
Baseline build based on your parts:
http://pcpartpicker.com/p/225DQ
THIS!
