Need help choosing graphic's card!
Hello everyone.So I want to buy a new graphics card for my system and I can't decide which one to go with.I can get either a HD 7790 or a r7 260x they're almost the same price where I live.I think r7 260x would be a better choice because it's newer, but I would like to hear your thoughts.
System specs just in case:
CPU : Phenom II x4 955BE
PSU : Corsair CX430
RAM : 4gb of Patriot 1600mhz RAM (Will upgrade to 8 in the future)
Motherboard : Gigabyte ga-78lmt-usb3
Links to the video cards (The site it self is not English but specs and stuff should be understandable) :
HD 7790 - http://www.kilobaitas.lt/PCI-E_16x/Asus/VGA_PCIE16_HD7790_1GB_GDDR5/HD/HD7790-DC2OC-1GD5/CatalogStoreDetail.aspx?CatID=PL_433&ID=496145
r7 260x - http://www.kilobaitas.lt/PCI-E_16x/Sapphire/VGA_PCIE16_R7_260X_1GB_GDDR5/O/11222-05-20G/CatalogStoreDetail.aspx?CatID=PL_433&ID=535824
So yeah... Thanks in advance!
the R7-260X is a better card, R7-260X has 896 stream processors vs 768 on the 7790. Also most R7-260X are higher stock clocked.
Long story short  R7-260X all the way.
^What she said. Plus the newer cards usually have better power management.
Hmm...Thanks for the help.Think I'm gonna go with the 260x
