Need help choosing Gpu
SAPPHIRE Vapor-X 100351VXSR Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
or
XFX Double D FX797GTDFC Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
please just keep it between these 2 gpu's cons and pros and your 2 cents thank you
Personally, which ever is cheaper. I think the Sapphire Vapor-X might be slightly better cooler, but at the end of the day, they are both 7970's with 3GB GDDR5.
Go for whatever is cheaper, they will both slay. Have fun.
