Hello, i need help, im going to build a new PC Soon and i have some problems (im going to use AMD)
The list of parts i will use are the next ones:
AMD FX 8350,
2 Corsair Vengeance 8 GB Ram 1600 Mhz,
3 HDD of 1 TB,
Blue-Ray internal burner,
AMD Firepro V5900.
AMD HD 7970.
and im lost in the things listed below
i need a motherboard who can use an AMD HD7970 and a AMD Firepro V5900,
new case,
new psu,
fans for system cooling (im trying to avoid water cooling),
a new display (2 if possible).
can you guys help me choosing the things i mentioned above? im lost, long time since i dont upgrade my PC (2009)
im going to use this PC for both gaming and rendering in 3D, i'm used to play FPS and Racing games and i will use a lot 3D Max, Revit, Maya & AutoCAD
Actually living in México D.F. So the price i have actually its 23,000 MXN (1741.63$) without the other things i need above. and im trying to spend less than 30,000 MXN (2271 $ , its my max budget)
- What size monitor are you looking for, and what resolution? Screen type (IPS, S-IPS, TN, etc.), hertz (60, 120, etc.) 120 hertz but i'm open to what you guys suggest.
- Do you need or already have peripherals? Yes, i have a keyboard but im missing the displays and a mouse
- Is there a retailer you prefer? Not really
Thanks for the support.
