Asrock Extreme3 or 4, or Gigabyte GA-990FXA-UD3. Both great and with a good color scheme.
how much overclocking do you want to do
None i am afraid i am going to ruin the cpu which is a amd fx-8350
Check out the M5A99FX PRO R2.0 or the M5A99X EVO R2.0 if the TUF is a bit high for you price wise. You still well get an awesome board with solid PWM and VRM and UEFI which will provide a great OC experience as well as easy performance tuning options depending on how much you may want to tweak or tune the system.
Hope this helps. Please enjoy the rest of your day.
