I need help choosing a netbook or small laptop, I have had the Dell Inspiron M102z for the past 4 years as a secondary laptop and it has decided to not charge and crash all the time. So I'm looking for a 11 - 16 inch netbook or laptop that can run League of Legends and Counter Strike Global Offensive at 60 fps (Medium Settings). The screen would have to be 1366 x 768 minimum. I also want the computer to be on the cheaper side ($400 - $600) if possible.
Thanks, If you have any suggestions please comment
<=$600 wont yield any exceptional options new so have a hunt around the 2nd hand market - gumtree, ebay etc. Otherwise something like this should run CS GO just fine, probably league of legends as well (I've never played it so I dont really know what it likes). http://www.shoppingexpress.com.au/buy/hp-250-g4-laptop-15.6-i5-5200u-4gb-500gb/N0C13PA has a slow 5400rpm hdd, maybe chuck in a ssd at later date for the OS.
