i have two asus matrix hd 7970 ghz and an fx 8350. i am looking for a motherboard that is compatible with these parts that is considered a good motherboard. im not sure of the price range i have on this motherboard so which ever motherboard is the best will be the one i want... i will be getting a dedicated sound card in the future so pro sound features on my motherboard is not required.... its not necessary but it would be cool if itwould be black and red to match my other internals. thanks for all the help!
http://www.amazon.com/M5A99FX-PRO-R2-0-990FX-Motherboard/dp/B008B6ONXK/ref=sr_1_1?ie=UTF8&qid=1381009906&sr=8-1&keywords=asus+m5a99fx+pro+r2.0
This should fit the bill. Also, that's quite the system you have there, make sure your PSU is up to the challenge of powering it.
Asus CrossHair V Formula Z black red colored and you dont need a dedicated soundcard, because this board has a realy great supreme FX soundchip. its one of the most expensive boards i know that, but its also one of the best boards.
1+
Well dedicated soundcard is better but still 1+ :)
750w enough???
The only two "red" motherboards on AM3+ are the Asus Crosshairs and a Biostar one which I wouldnt touch with a bargepole
I have the same hardware as you, I tested out the watt usage with a watt meter and posted in a topic here;
Peak wattage usage with overclocks was about 700 watts.
750 should be enough, provided its a good brand with good materials.
There is also a red/black/brown Asrock board but its realy hard to find.
Asrock Fatal1ty 990FX Professional. 12+2 powerphases digi vrm, and goldplated capacitors.
i would say if you realy want a black/red mobo then go for the Asus Crosshair V Formula Z. if color is not an issue, then go for the Asus Sabertooth 990Fx R2.0 or Asrock extreme 9 you say you want the best..
