OK I'm going to start Developing for Blackberry,Android,IOS, Windows and other platforms.Also I would be playing a few games like ROM,WOW,NFS and games of that nature. I need good battery life, 1080P HD/3D Screen (3D Optional).
Also I would like to run like 5 OSes on it.
Specs I'm looking at
1TB HDD/HHD/SSD
i7 (maybe 3rd gen,dont care once its I7) maybe i7-3770K or i7-3960X
Im a Nvidia fanboy so im looking for Nvidia Graphics card
I will be travelling alot with it, well thats about it.
An MSI laptop like the one Skullabyss posted would be a good choice. When i was shopping around for a laptop for a good friend of mine, MSI blew everyone else out of the water in terms of price to performance.
Thanks for responding guys but will the Bluray Drive be able to play regular CD/DVD ? cause I was reading some where that it cant and im thinking about the Samsung because it got a better graphics card.
I think those are terrible Alternatives, mainly causethat's expensive and you can get it built with higher specs for less. I mean if you travel a lot a 15 inch would be the most convenient size and it's 2 lbs lighter. I would recommend a custom build maybe,that way you can meet all your specs and have a sure quality build. Maybe Check stealth machines.com because I plan to get mine from there and it's cheaper. Ifni don't get that then its an ultra book i plan to get.
I have the Ideapad Y580 which I acutally scored from the Lenovo Outlet website refubished for $360 (believe it or not). It has the specs that you are looking for, although you probably won't be able to get it as cheap as I got it there are probably some deals around somewhere.
