Need help choosing a CPU
http://pcpartpicker.com/parts/partlist/ this is the build I was planning on building but I changed my mind in the pentium because it only has 2 cores, I want a CPU around the same price that will do just as well if not better with 4 cores but I don't know any. This is my first build it's going to be primarily used for gaming and I want to learn how to code on my freetime.
-thanks
EDIT: http://pcpartpicker.com/parts/partlist/ I changed the motherboard and case
try looking at some AMD quad core APU's. those are quad cores that could probhably beat the pentium out of the water.
like the x4-750k
or some of the fx processors (if you want to splash a bit more money)
ok thanks, I will look into it right now
pair that with a radeon card (prefferably R9 270x) and some high speed ram, that pc will rock pretty much any game (except ubisoft of course)
How's this http://pcpartpicker.com/parts/partlist/
permalink in the top left of the page, please.
http://pcpartpicker.com/p/jQCvvK
save on ram -> get better GPU ?
Edit: that 750k is prolly too weak to pair with 280
Intel:
http://pcpartpicker.com/p/WJVyZL
AMD:
http://pcpartpicker.com/p/sj2nMp
http://pcpartpicker.com/p/cqmvvK
