Need help choosing a CPU cooler
Hi everyone.I want to buy a new CPU cooler to replace my AMD stock one.
The CPU is an AMD Phenom II X4 955BE (Stock at 3.2Ghz and I would like to overclock it a couple hundred Mhz).
Just in case, the motherboard is a Gigabyte ga-78lmt-usb3.
I want a cheap and decent cooler and I can choose from a DeepCool Gammaxx 300 or a Cooler Master TX3, maybe a Cooler Master hyper T4 (If it's much better than the other two).
Any help would be appreciated!
Oh and please don't recommend me to get a Hyper 212 :d
Thanks.
The T4 will be your best bet
Also, what's wrong with the 212?
I would probably go for the TX3 my little brother has one in his system and its pretty silent havent really checked temps as its not my computer and I have a Noctua NH-D15 myself, so I cant speak too much on how well it cools, but from what I have read its a good cooler in that price range. I dont know anything about the other coolers so I cant comment on them
There's nothing wrong with it, it's a great cooler, it's just that I don't have the money to buy it because it's significantly more expensive where I live.
Don't forget to buy the thermal paste if your new cooler doesn't come with it.
tx3 does what it says on the tin, I use one on my x58 test board, noisy though at high rpm. Takes all of 5 minutes to install.
all coolers will come with some sort of TIM, grease or paste.
