I've just built my new gaming PC and my friend offered a solution for my OS. He gave me a Windows XP OEM disc with a manual and a Windows 7 Upgrade Disc. Now on installation of Windows XP I realised that the "Certificate of Authenticity" wasn't in the place it should be. As such I can't exit the installation and I'm almost certain that I can't wipe the hard drive from the BIOS. If I attempt to start up the computer then it immediately goes back into the Windows XP setup process.
You can do a clean install of Windows 7 from the upgrade disc. In fact, you'd have to do that anyway after installing Win XP. Why are you installing XP?
as long as you boot into the disk you should be given the option to format, if it goes back to where you were in the setup you're probably booting to the hard drive
I've made sure to boot to the disk. I'm assuming you're talking about XP here. But even when I do this (going through BIOS, setting the Disk as Boot) I'm still presented with the setup screen. It even does this without me putting the disc in.
try unplugging the hard disk sata cable, then when the cd spins up plug it back in, because if it does the same exact thing whether the disk is in or not it must be booting to the hard drive for some reason
otherwise if you can get either a bootable partition manager (gparted/minitool partition wizard/etc.) or Linux live cd they will be able to format it for sure
I would double and triple check your BIOS settings. If the boot order is properly set with the DVD drive at the top of the list, there's no way you should notget a prompt to enter Win 7 setup.
Just to be clear, the Win 7 disc is already in your DVD drive when you turn the computer on, right? What motherboard are you using?
