I need help buying a GPU. There are so many out there, and I just can't make a decision. I will be using the Adobe Master Collection, playing hardcore games, and using medium 3D. Any help is appreciated.
how much are you spending and what are your current pc specs and psu wattage/amp?
I will spend up to 2 grand. I have an overclocked i5 processor to 4.5 GHZ, 16 GB of 2133 RAM, and a 1200 watt PSU.
Gtx Titan
That fits my needs perfectly. Thanks a lot.
I would say that the gtx 780 or the ti edition of it would be best if adobe does use sli configs but if it doesnt a titan would work fine.
personally I would get a 780 other wise if you are going to wait you can get a 290x non reference later. Then you can also go SLI or CF or go with something like 690 or 7990. Is your motherboard multi gpu capable if not you will need to stick to some sort of single card.
This is the card I need. And yes, my motherboard can support multiple GPUs.
Thanks guys. This is the card I will get.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130918
